Hey - I'm new here! First post: I'd like to change the lights inside my mirrors, you know, the ones that light up when you unlock the car... For the life of me, I can't find an access point! How do I do this? Much appreciated!
-Byron
-Byron
:welcome:
Please post your request once and only once (see the board Guidelines/Rules).
Your second post has been removed.
I haven't had the pleasure of changing these lights yet but I'll look through the manual and post anything if I find it.
I have no diagram, but you have to dismantle the mirror front and rear shells, it takes some time and the parts are very brittle to work with.
Can you be more specific as to how to dismantle them? My lights are out too and I'm coming up pretty empty on web searches.
  • 3 months later...
Here u go maybe this will help, sorry for bad page layout-out of time, but you'll figure it out ;)))
Mirror light.pdf
cOOk!e you ROCK!! First posts here and you solved an issue we have had forever. Reading the PDFs I know I can walk right out there and do the install. THANKS!!!!!!!!!!
Here u go
Removing and installing mirror glass.pdf
Removing and installing housing for rear-view mirror.pdf
You do not have to remove the housing to replace these lights... just the mirror glass. You can then remove the light housing and wiggle it out enough to replace the bulb. I did this when I replaced my stock bulb with xenon look LED's. Takes less than 5 minutes. :)
David
