Changed both O2 sensors on Porsche Cayenne (V6) in Bank 2 and still getting following Error Codes: P0160 (Bank 2 Sensor 2)/P0159 (Bank 2 Sensor 2)...Could the new BOSCH O2 sensor have failed ALREADY (Error came on about 2-3 hrs after installation)? Any help would be greatly appreciated!!!
P0159 Oxygen Sensor Aging After TWC, Bank 2 - Above Limit
Possible fault cause
- Oxygen sensor faulty
- DME control module faulty
P0160 Oxygen Sensor After TWC, Bank 2 – Open Circuit
- Open circuit in the signal wire and/or ground wire of oxygen sensor
- Loose contact in connector
- Open circuit in B+ and/or negative line of the oxygen sensor heating
- Oxygen sensor faulty (heating resistance too high)
Check the wiring.
If it all tests ok then perhaps try a DME reprogram.
DME is what exactly?
Check the wiring.
DME = Digital Motor Electronics - Porsche's engine management system, the Bosch "Motronic" system, that controls both fuel injection and ignition functions. (see the Glossary link at the top right of the page)
OK...Thanks!
Bank 2/sensor 2 is behind cat on left (closest to steering wheel) correct?
Edited by Loren
Removed ALL CAPS post - please do not post in ALL CAPS - that is SHOUTING!
