996 TT 2002 tip with DTC p0491 p0492
P0491 Secondary Air Injection System, Bank 1 - Insufficient Flow
P0492 Secondary Air Injection System, Bank 2 - Insufficient Flow
Possible cause of fault
- Electrical fault in power supply or line between relay and secondary air injection pump
- Secondary air injection pump relay mechanically faulty
- Mechanical fault in electrical secondary air valve
- Pneumatic secondary air valve faulty/sluggish
- Electrical fault in secondary air injection pump
- Mechanical fault in secondary air injection pump or secondary air injection pump blocked
- Vacuum system leaking
- Air hose to secondary air injection pump slipped off or constricted
Check the connector (perhaps they left it unplugged) then fuse (40A on relay panel near DME).
Thanks Loren
  • 3 months later...
My car just had the same codes, p0491 and p0492. I had them cleared and they have not come back. The weather was extremely cold that day, but not sure if that had anything to do with it. I can post my full readouts if anyone cares. Just wondering if anyone else had the same experience. Thanks.
--BM
--BM
I have. They came back. Took it to the dealer, they replaced "some valves" and the codes came back. Will take the car there again in March...
Thanks, if I get the codes again, I'll post here, reading up on it, seems like a non-essential part of the car, heats up the catalytic converters, but if not working correctly it may not pass state inspection
March 12th, still no codes, hopefully I haven't just jinxed myself....
  • 5 years later...
