noticed big puddle in front this morning. I used the wiper fluid wash for the litronics last night. while driving. Noticed big puddle in garage this morning. Filled tank again and its leaking near where front center radiator would be. turned lights on and turned spray on again, and the leak is more exagerated. Any hints as to what could be? Broken hose? Fix?
If you have headlight washers (factory Litronics) then it sounds like a hose behind the bumper.
The rest of the pumps and tank are in the upper left front fender well. These are accessible after removing the wheel well liner (and tire/wheel).
