Help needed in Removing intake manifold (coolant pipe replacement)
Please help. :help:
Yesterday i started coolant pipe replacement on my 2004 Cayenne S. Every thing went ok till the last bolt witch hold the intake manifold. (pasanger side). The torx go round inside the bolt. Torx bit is ok but the bolt is destroyed :-(. now you can tern the key inside the bolt without afford.
:help: Please help how to remove this bolt and intake manifold. Space is very limited because of fuel rail. Is it possible to remove fuel rail without removing first intake manifold?
Best regards
Marek
