I would expect that whichever one works when the wing is down normally would continue to work.
Why would you disable the wing?
Hello
Thanks for your answering Loren, i disabled it becouse i buy a wing without a brake light and when i desabled the wing the hight brake light not working. only if i fixing the brake light from the original wing its work.
In most cases on the previous model if you switch to a fixed wing then you needed to change the small wing wiring harness to the same harness the Aerokit (fixed wing) uses.
If you are switching to a Porsche fixed wing then the harness and or any programming should be included.
Thank You Loren
