Removing and Installing engine
I thought you guys might like this. This is from Porsche on how to remove and reinstall the engine. WM 100119 Removing and installing engine Tools Designation Type Number Description Master Gear unit elevating platform Workshop equipment WE 1206 Flexible-head socket wrench, a/f 10 Special tool 9824/1 Torx Micro Bit T45 Special tool 9824/3 Spring compressor VW tool VW 552 Technical values Location Description Type Basic value Tolerance 1 Tolerance 2 Ground cable
  • 4 months later...
  • 4 years later...
