Pardon my ignorance on what its called but I think its refered to as the AOS. Its the pump that come on when the engine is cold during start up. My question is when I took a look at the engine the other day i noticed the hoses below this pump look as if some oil had leaked out on them. Not heavy, very light. Sorta like an over flow at one time. I started the car up and felt around but couldnt find anything so I just wiped the hoses off. Could I have a hose loose? Does this pump have something to do with the oil? Car runs fine!! No issues.
The pump is the air injection pump for when the car is cold. Part of the smog equipment. It is an electric pump and has nothing to do with oil.
