driveline vibration when releasing clutch in 1st...normal?
Just bought an 987 base boxster. When I release the clutch on 1st I get a driveline vibration that appears to be uneven clutch action. The car has 9k miles. Maybe this is normal for Porsche. It only happens on slipping the clutch to engagement.
What your describing does not seem normal. just to make a comparison. I have a 987 (2006)base w/6 speed. I experience no vibration what so ever. And the shifting is very precise and smooth. I'm sure you will receive some very helpful leads on your question. I just wanted to give you a comparison that your problem doesn't seem normal.
Kimo
