I recently purchased a 2006 Carrera 2S Tiptronic that has 18k miles. It had the 20k service performed by the dealer prior to my purchase and I have put approximately 300 miles on the car.
With the engine fully warmed up and cruising on the freeway at approximately 2800rpm my oil pressure is pegged on the gauge at 5. The manual indicates that oil pressure should be 3.5 at 5000rpm. Pressure does go down as rpm is reduced.
Dealer tells me that this is normal.
Anyone with the same car -- what pressure are you seeing?
