Sign in to follow this
andy102
Nav code question
I left my 996c2 2001 with the battery disconnected for a month.
After reconnecting it the PCM1 asked for the radio code like normal, but then wanted the Nav code as well.
I have the radio code but not the Nav code, which I have never needed.
I would be grateful for any advice.
Share this post
Link to post
The codes are often recorded in the DME Vehicle Data, which can be read with a PST2 or PIWIS tester. Drop me a PM if you are near me.
Otherwise, as Loren says, an OPC should be able to get them for you. Some charge, some don't.
Share this post
Link to post
Thanks guys.
I fixed the problem, buy disconnecting the battery again, fully charging and reconnected it.
This time it only asked for the radio code, so now it all works find.
Odd but worth remembering.
Share this post
Link to post
