hello and thank you for your help.
i am looking for the place of the secondary air injection pump, i can't find it in the engine compartiment.
the reason why i'am looking for it is that i have a hose (not sure of english term) between the electric change over valve and the air change valve that is missing. and the air change valve is "on" the secondary air injection pump. so if i find it i can plug in the hose.(if someone have a picture it will help me a lot)
i am very sorry for my english and hope that you can help me
it is a 2.5 boxster 1999
many thanks for taking time for reading
thank you for your answer i have already this document. in this document it is the hose 25 between the 3 and 2
but i can't find where is the 2 that's why i am looking for where is the secondary air injection pump because if i can find it i will find the number 2
again thank you for your answer
It would help if you update your profile so we know where you are.
If your car is a European car it doesn't have a secondary air pump. Only the OBDII cars have this device and the secondary air injection.
-Todd
Edited by tholyoak
sorry i'm from france and my car come from germany.
i don't understand, i thought that every boxster got OBDII; mines have it
if i didn't have secondary injection air pump why did i get the Electric change-over valve ? (and also the vacuum reservoir)...
my problem is on the electric change over valve there is a hose which come from the vacuum and the hose who go to the air change over valve is missing, i think it is not good for the engine...
if i unplug the electric change over valve after some km the check engine light goes on.
i am very sorry if i explain bad my problem
The air pump is located on the right side of the engine bay,all other components in that pic are on the engine.
Here it is on my 2.5. You can see the blue electrical connector that powers the pump.
hi!! many thanks for this picture!!!!!!!!!!!
i understand now why i can't find it!! i didn't have it!!!!!!!
so now my question is why i have the other parts?... (vaccum, electric change over valve etc)
if is ok for the engine if i drive like this??
