Anyone any ideas as to why my RHS fan isn't working, have checked the fuse and the blades rotate freely, just wondered if there was a common fault.Thanks.
I assume you are referring to the radiator fan. Does the fan work with the AC on? If so, it is the ballast resistor that needs replacing not the fan itself. It is kind of a PIA job to replace the resistor but I did it in my driveway. There is some instructions here somewhere that outlines the process.
Good luck;
James Greer
Thanks guys, off for a few days to France, will get to it on my return. Funny thing is shortly after buying the car I discovered that the RHS fan didn't work, that time it was the fuse, defo not the fuse this time.
