Just got first CEL... P0300, P0301, P0302 for "random cylinder misfire", cylinder 1 misfire and cylinder 2 misfire. It happened right after start-up this morning. I went out and got an Actron reader and got these codes.
Ques - how do I interpret this and is it an anomolly?... a glitch?... loose cam chain?... how should I be concerned?
thanks,
kj
33,000 miles.... no spark plug, coil pack work done yet. Just had new lightweight flywheel, spring clutch and IMS retrofit (Durametric confirmed no changes to cam timing) about 350 miles ago. Thanks for the lead and possible point to the cause - didn't think of that. I'll clear the codes and see if it comes back and brace for another bill (parts).
thanks for the quick reply Loren... alot of people sure count on you.
regards,
kj
