Fuel Pump Removal
i think loren will be able to answer this got fuel tank lid off got pump half outof carrier but does not seem to want to come out is there wire or pipes holding it in dont just want to pull any idears or could you send mw photos of how to remove firemark1810@btinternet.com many thanks people
Lift fuel tank sender unit and disconnect electrical plug connection. Press the pushbutton (arrow) and simultaneously pull off the fuel lines. Carefully lever out the fuel tank sender unit.
