Hello, I was in a tight spot and had to down shift pretty hard for a short period, a few minutes later, I noticed the "check engine" light come on.
I tried the gas cap, opened and closed it and the car sounds and runs great but the light stays on.
I have read horror stories about this engine, any suggestions?
If you want to be certain have the fault codes read.
There are several hundred things that can turn on CEL so only the fault codes tell you for sure.
Thanks, will do first thing tommorow
