Have a 2004,C2,six speed,15,000 miles,using Mobil 1,0-40 synthetic oil. I am noticing that the oil pressure gauge fluctuates up and down,never much,it doesn't go low,or too high,it just stays put or jumps around a very little bit,so the pressure seems to be ok. 4-5 bar at 3000-5000 RPM,1 1/2-2 at low,idle RPM. Should I be looking for trouble here or is this reasonable?
Any thoughts would be appreciated.
Duke
Have a 2004,C2,six speed,15,000 miles,using Mobil 1,0-40 synthetic oil. I am noticing that the oil pressure guage fluctuates up and down,never much,it doesn't go low,or too high,it just stays put or jumps around a very little bit,so the pressure seems to be ok. 4-5 bar at 3000-5000 RPM,1 1/2-2 at low,idle RPM. Should I be looking for trouble here or is this reasonable?
Duke
Those numbers mirror what I see in my '02 C2.
I am not concerned about the pressures,but the minor jiggling or moving slightly up and down at a given RPM that bothers me. It usually goes up or down as RPM changes,smoothly,and remains stationary as the RPM is constant. It' jumps up slightly and then back erraticaly. Thoughts?
Duke
Sorry to drag up an old thread - was there a resolution to this? My pressure gauge jiggles a bit too and looking for solutions unless they all do it?
They all do it mate, don't worry about it, you've just got a bit of the classic "porsche paranoia"
Ask your mechanic next time it's in for a service.
If it reads 0 and you have a warning light on then start to worry, otherwise, enjoy! :)
