2001 Boxster S Tiptronic with 24K miles.
Noticed lately that throttle reponse coming off idle is not as sharp as it used to be. There seems to be a dead spot just off idle or when lightly "blipping" the throttle. If I press lightly on the pedal with the transmission in park and raise RPM to around 1200 RPM, engine speed fluctuates +/- 100 RPM. After doing that and releasing throttle, idle will sometimes sit around 850-900 then eventually drop. If I punch the throttle, response seems to be much quicker.
What does the group recommend? Clean throttle body? Can someone give me a link to cleaning instuctions?
Bruce
