my 02 996 c2 starts fine when cold, but once every three months it seems to defy me when fully warmed up.
the starter cranks slowly as if the battery is dead - it's not
after three or four times i give up and it starts fine after an hour or two or an overnight rest
this is ok when close to home, not so when away, as one can imagine
the mechanic whom i trust says everything's ok after testing the engine extensively
can it be the clutch switch, starter motor, the starter or something else?
any thoughts?
big thanks
most likely it's the starter solenoid or starter relay,,,
I would start by checking the ground strap, battery connection, solenoid connection
any thoughts?
big thanks
some connection is shorting due to heat expansion. tighten everything up... good luck.
ditto on judgejons advice, but remember, you have to remove alot to get to your starter and even then you need several extensions to reach it..so if you do all that and it turns out your starter is going bad, you will have alot of work reinstalling your air intake throttle, alternator etc., and repeating until you can have a new or rebuilt starter ready to replace. So it might be a good idea to have a starter in hand before you start the removal process. Of course it matters less if this isn't your daily driver.
Search the site as I'm sure this fault has been covered before. IIRC the cure was a battery cable junction block for the starter that needed cleaning and tightening.
  • 3 years later...
thanks all for your input. there was a simple solution...or two. it turned out MY FLOOR MAT was riding high on the bulkhead preventing the clutch switch from activating the starter...how stupid is that? i attached the mat to the floor and it starts every time. had to replace the switch as a precaution - $35 expense. LOL
