2002 996 Cab, manual
Power window fuse is popping, I believe it is C3, 15 amp, pops when new fuse is put in. Just had drivers door panel off, will take a look there first. No water on the carpets. Any suggestions.
Fuse C3 -- 15A -- CU ALARM, CL POWER WINDOW, SUN ROOF, CU POWER TOP, INSIDE LIGHT
You may need to eliminate each other possibility.
Loren, thanks for the reply, the top goes up and down fine, and the windows lower and raise with the top. With this fuse blown the door locks do not work, nor do the interior lights. The alarm seems to work though, at least it beeps.
I did just put a new latch on the drivers side, maybe it is the locking mechanism? Alarm beeps when you press the button, and beeps twice when you manually lock the door.
One beep means a zone is open - two beeps mean there is an alarm fault.
I think it is worth rechecking the previous work.
Loren, can you tell me where the window relays are?
Sorry, was thinking about the wrong car - no relays for the window motors.
C3 fuses - interior alarm sensor, central locking button, tilt sensor, sun sensor and the external consumer terminal.
Hi Loren, looking at the fuse diagram I see that there are other fuses for the locks, windows and alarm. Could I take these fuses out, put C3 back in and then put the others back one at a time and see which cause C3 to blow?
All fixed, with the door open, fuse did not pop, close door slightly, fuse pops. Took door panel off, jiggled wires, nothing out of the ordinary, put it back together in stages, no fuse pop. All back together, and it is working fine, odd that I didn't find any thing actually wrong. Although I did park it on the curb the other night, I would be upset too.
