I have a 2005 987 that has PSM, PASM, and a 6 speed manual shifter. I am considering installing a performance chip that claims to boost HP by 50+. Anyone have any experience with the results of changing the factory chip? The chip I'm considering is a RS4 performance chip.
thanks,
lee
Do you honestly believe you will get 50 hp for $60? From what I know a real performance chip (and I don't believe this is) only really helps when you have made other expensive upgrades. Real chips run from $600 to $1000 and you have to run high octane gasoline. Do a little more reading on performance chips before you waste your money and possibly harm your car. Read the thread today on Softronic flash. This reprograms your chip and costs quite a bit. Good luck, Robert.
Edited by ALLSPEED
