944 Fan Rrelays And Switch
Hello,
I am a new member and I would really appreciate your advise.
I bought a 1984 944 in non-running condition with a swamp in the passenger foot bay. I have nursed the car into running condition. I have replaced the cooling fan switch and the radiator to stop the boil over effect.
When I got the car it had no relays. I have obtained them from junkyard cars. I have multiple relays which I have tried.
In position I cooling fan I had a PN 944.615.113.01 and Position III had a PN 141951253B. In this scenario I had all fans working correctly except with key off there was no cooling fan after shutdown.
New set-up is Position I= relay PN 141951235B and Position III is PN 944.615.113.01. In this scenario the Cooling fan only works when key is off, and the air conditioning switch does not actuate the other fan at all.
Thanks in advance
944mania
