Hello .. I had my porsche cayanne 2004 And i change the Coolant pipes and when we Finish i Wondering couse i get high tempretaure between 90C and 100c :S
is there Any Software for Computer or anyone can help ..
note : everything is ok .. no leak :( but i its high tempretaure .. even i change tempretaure sensor !!?
yeah , everything is working but the fan working so late !! its start on 100c !! And the Air Condtion is Working too
Also ther's no No Air in System ... and if the Air in sytem it will be start the High speed on the fan.. but everything GUYS is normal .. but why WHEN I CHANGE THE PIPE COOLANT i hade this FAULT ???
On the top rear of the engine, starter motor area, you find a plastic support with 3 water hoses you have to remove in case of a light alloy water pipes install. The 3 water hoses are side by side in the support ready to connect on 3 water pipes, side by side, behind the engine. The order is not logical (most left on most left, middle on middle, etc.) two of the hoses are connected wrong, they must be crossed. This situation is responsible for the overheat problem you describe. Take a look in to an other Cayenne for the right order. Hope it helps.
U r Ryt And yeah sometimes it will be wrong !! but what i told you .. Everything is PERFECT AND THE 3 HOSES THEY R IN THEY PLACES.. AND SOME HOSES FOR HEATER I THINK !!! AND I U WANNA MAKE SURE THAT THE SYSTEM COOLING IS OK SHOULD U TURN THE AIR CONDITION BUT IN HOT WAY..
I HOPE I CAN FIND THE REAL PROBLEM !!
