remote
Help here remote not working to lock or unlock car durametic said it was a fault code 60 but where do i start to find the problem how do you trouble shoot this thanks for any help i can still use my key
I would erase it and see if it comes back - you can get this fault if you try to lock the door before it is shut.
If it keeps coming back then investigate.
Fault code 60
Central locking limit position 'Locked' not reached
Possible cause of fault
- Central locking switch faulty
- Short circuit to ground/open circuit in wiring between the alarm system control module, central locking switch or door locks
- Driver's/passenger's door lock faulty
- Control module faulty
