fault codes read out question
I need to know what the following fault codes are that were read out on my car:
P1128 bank # 1
P1130 Bank # 2
I understand they are oxygen sensor codes, but i would like to know what might have caused them to light up my check engine light.
All help would be appreciated!
Steve
P1128 Oxygen Sensing Adaptation, Idle Range, Bank 1 – Above Limit
P1130 Oxygen Sensing Adaptation, Idle Range, Bank 2 – Above Limit
Possible fault causes:
– Incorrect signal from MAF sensor
– Intake air system leaking
– Fuel pressure too low
– Volume supply of fuel pump too low
– Fuel injectors fouled
– Exhaust system leaking
I would start with cleaning the MAF.
Thanks again Loren, I think I'll check the MAF, I pretty sure there is a DIY for old fogies like me, yes?
