Connect a Remote PSM Information Light?
I would very much like to have a 'PSM Information Light' - that is, the '!' light on the dash that comes on when PSM is activated - that is easy to see when I'm on the track. I drive with PSM switched on, but I want to use it to help me be smooth, so I have to know when it is being activated. You can't always see the light on the dash, and I can't always feel when it activates.
Does anyone know what wire I can connect to? It's an '02 996TT with Tip.
Edited by PyroKerry
Loren, first let me thank you for the reply. You have an amazing forum.
Now, you mean the switch used to turn the PSM on and off? I know that switch has a light that indicates when the PSM has been switched off (and a corresponding light on the dash), but I didn't think that switch light also came on when the PSM was being activated.
I wondered about that. I think I can find the signal wire in the '00 schematics for the instrument cluster light, but not the '02. What do you think of accessing the instrument cluster lights, and spot soldering to that circuit board where it feeds the PSM Information Light?
That might work. There are no schematics of the internal working of the instrument cluster only I/O. Since the lights are part of the cluster your guess is as good as mine.
