996 C2 blows smoke when shifting from 3rd to 4th
I have a 2002 996 C2 Cab with a 6 speed and 50,600 miles on it. I was occasionally experiencing the "smoke at startup" issue mentioned by others in the forum. More recently, I was shifting from 3rd to 4th gear on a spirited drive and a lengthy plume of smoke came from the exhaust. It happened twice in the same day. I looked at Renntech forums and saw it was likely the AOS so I took it to my mechanic for diagnosis. He diagnosed it as the AOS and replaced it last week ($683). Today, I was driving it in a spirited manner and shifted from 3rd to 4th (at almost 7000 rpms) and experienced a large plume of smoke from the exhaust again. Any thoughts of what might still be causing this? Any help would be greatly appreciated.
Edited by bdknights
Once oil gets into the intake it can take a while to burn out.
I would give it another week of driving and then if it is still smoking take it back to the same mechanic.
Loren - thanks for the recommendation. I did send a note to my mechanic to get his input as well. Hopefully it is just a matter of burning out anything that might be remaining in there and not something more serious.
