Led resistance
I replaced my 3rd brake light last week and noticed that my cruise-control stopped working, does anyone know how much ohm resistor you need to be able to use led 3rd taillight? i only had a 6-ohm here but that didn't seem to fix the issue..
Any help is appreciated.
I do not remember the solution. But is has been mentioned before. A LED draws less power than an incandescent 12 volt bulb. Cruise does not work if the brake bulbs are burned out, or if the computer thinks they are because the voltage draw from the LEDs is less than what the computer wants to see. So you use a resistor to trick the computer into seeing the electrical draw it is happy with. But you already knew that..
