my00 boxster 2.7 base has TC
will be replacing clutch master and slave cylinders because of leak in driver footwell
thinking why not bleed the brakes at the same time, however car has TC
according to ALLDATA only the S model has TC but i do have the illuminated TC
button. do i have the 4 channel system requiring ABD reset?
Edited by abboxster
You have a four channel system and can bleed the brakes in a normal way. To my knowledge it doesn't much matter if you have ABD or not.
