Need some opinions. I just moved my 2001 C4 out of the garage to work on another car and everything was fine. Went to move the car back in later and noticed an engine knock coming from the right side of the motor. Turned the car off and restarted and it was still there. Sounds kind of like a lifter noise but from the right bottom of the motor. It increases with rpm's. Car has 24,000 miles on it and I bought it new in 2001. No oil leaks ever, but it does also have a slight vibration since the noise appears. Car seems to run ok and no cel. Does anyone have any experience with something like this? I'll call my Porsche dealer tomorrow but would like some of your opinions.
Thanks, ED
These cars don't like not being driven. Likely just lifter noise from the oil getting up into the engine and up to temperature. Give it a good drive (long highway journey).
Of course, check oil levels, etc. Old oil should be replaced to help keep things well lubed.
