I purchased the durametric diagnostic tool but I don't understand how to use it very well. I ran the "short test" on car and it gave me the following codes:
Short Test
Bosch Digital Motor Electronics Motronic 5.2.2
Current Fault Codes
P1602:
Supply voltage Open circuit
FREEZE FRAME INFORMATION
P0300:
Misfire damaging to cat. converter
P0301:
Cylinder 1 misfire damaging to cat. converter
P1319:
Misfire emissions-relevant
P1313:
Cylinder 1 misfire emissions-relevant
P1411:
Secondary air injection system Cylinder (4-6) Signal implausible
P0410:
Secondary air injection system Cylinder (1-3) Signal implausible
Airbag B05
Current Fault Codes
45:
Belt buckle, driver
46:
Belt buckle, driver
3:
Supply voltage
Seat Memory
Current Fault Codes
26:
Potentiometer left mirror Open circuit vertical
24:
Potentiometer left mirror Open circuit horizontal
I was hoping the software would help me understand what to replace/repair, but I don't understand the codes. Am I doing it correctly? Some advice please. Thanks.
By the way, I have a '99 C2, 3.4 liter engine, manual transmission
Does the car run okay? Is the CEL on?
I am not sure the Short Test by be history.
I would clear all the codes and then run the individual tests for specific faults. Then report back here.
I'm curious, just how much is a durametric. I'm thinking to buy one, new or used. any sellers out there too?
Car does not run good at all. Missfiring, stuttering, etc. CEL is definitely on.
I can clear the codes, but am unsure how to run individual tests for specific faults. Can you shed a little light?
Sorry to be so needy, but I am not so familiar with the durametric unit and the video demos on their websight won't play on my computer.
Thanks in advance.
Jeff Smith
