When I place the temperature on the Climate Control unit to a warmer temperature smoke billows from the vents. I think this has to do with the exchange device that provides heat to the cabin but I'm not sure. Can someone verify why this may be happening?
Oil is leaking onto the heat exchanger that provide heat for the climate control. The valve cover gaskets are a very common source of leakage on this model. I would get this repaired asap.
