Fitting '911' badge to engine lid ?
Hi
I'd like to remove the Carrera badge and replace with a '911' badge. What is the best way to remove the original badge and what measurements do I need to replace it with the '911' badge?
Cheers Guys :thankyou:
The letters are just held on with double stick tape. Use some paint safe adhesive cleaner to remove any residue.
Just center it with the bottom of the numbers starting at the same place the letters do now. Be sure to measure before you remove the old one.
Hi
The original letters come off pretty easily with a hair dryer, or heat gun on low...Just be careful not to overheat. Afterward you can clean off with alcohol to prepare for new emblem. Just a tip that may help removing.
Good luck
DC
Thanks boys for the tips. What about measurements etc, dont want it looking stupid !
I would measure the distance from the bottom of the deck lid up to the bottom of the current emblem.....Then just center it from left to right....Piece of cake :)
Good luck,
DC
