Help with boxster 99 boxster Dme
Been a member for awhile ,just nevr posted.
Been reading psts for years and finally had courage to do a 2.7 swap to my boxster.
Evry thing went smootly as you all explained.
My question is ,will a 99 3.4 dme map from dealer work on my 01 2.7 running a 5.2 2 motronic
john
Hey there, yes if you have a 5.2.2 motronic it can be re-mapped to a 1999 3.4L 996 map. You'll need the programming codes and a PST2 to do so, which a dealer should have access to the codes if you provide proof of ownership. There is a fair amount of rewiring required though... I believe tholyoak is the man you need to get a hold of.
If you are a contributing member you can get the details here : http://www.renntech.org/forums/topic/13527-34-swap-pdf/
Edited by logray
Thanks, for quick response logray,ive done every thing tholyoak posted and it was great help.
What i did was swap a 2.5 with a 2.7.
Added resonance wires to dme
Car runs fine .just want to activate resonance vacum.
All dealer has to offer for remap is a 99 3.4 file,
