Cigarette lighter assembly for 986/996
How are your going to drive with a cigarette in each hand.
If you wanted it lighted you also need 996 652 102 01.
Might consider the non smoker socket - not sure if that holds plugs better than the lighter socket.
Thanks Loren & Jeff!
What is the non-smoker socket and part number?
So, what I'm trying to accomplise is to add a second lighter for another accessory such as to power my GPS unit. This means I need to splice into the power for the original lighter.
I believe I need the part numbers for the plug that plugs into the lighter socket along with 3 connector power pins for wire harness I need to make.
Thanks in advance,
Duster
