Gas cap pops open by Itself - help!
We have an 03 cayenne which has developed a strange problem where the gas cap pops open by itself while car is on. You can hear the lock mechanism opening while in car every few minutes
Does any one have an idea for how to fix this or troubleshoot?
:welcome:
Check to see that the clip is on fuel door (item 12 below).
You asked for tips and did not say what you thought the problem was - a common problem is to lose that clip then it will not latch and stay closed.
955.504.899.00 guide sleeve (item 8) -- US MSRP $1.64 -- I doubt this is it unless it is damaged. More likely the solenoid assembly.
955.624.773.01 Actuator (solenoid) -- US MSRP 27.05
