Window regulator fix
I found this fix for windows that do not roll down when you open the door.
http://986forum.com/forums/general-discussions/25704-window-regulator-permanent-fix-stretched-cable.html
I did it yesturady and it works like a charm. A few tips. Its difficult to cut the green plastic furelle, I used a Dremell carefully. Trying to put the bike adjuster on was hard unless you remove the cotter pin on the other side of the cable by the spring. This allows you to stretch the cable other way so you can fit the adjuster in the hole with out grinding or drilling the hole. Once you get the adjuster in you need to pull the metal piece with the spring downwards and insert the cotter keys in. It appears that the cotter keys is some sort of adjustment for the cable, thus we have four adjustments from the factory. I would suggest to check if you can tighten this to the last cotter key before doing this modification. After that you are ready to use the screw to adjust the cable.
