  • ×   Pasted as rich text.   Paste as plain text instead
  • Similar Content
    • By royp4
      I am posting this hoping it will benefit someone. I have a 2003 996 c2 cab. Recently the brake lights went out. After screwing with the brake pedal switch, I discovered that it needed to be replaced. Manually depressing switch with my finger showed that this was an intermittent problem. The interesting part of this is that I found that when the switch went out, neither the hazard flashers nor the cruise control would work. After replacing the switch, all these problems resolved. The switch is in a hard to reach location {of course}. While I could visualize the switch by lying on my back in the driver's side footwell, I had no room to manipulate. After a couple of hours of frustration and cursing, I found that I could manipulate and change the switch by sitting in the driver's seat and blindly removing and replacing the switch.
    • By 118d
      hello , i want to replace the brake pads on front and rear of my Cayenne 958 diesel 6/2012
      Whit the black calipers , i have already order the parts , but i have some questions ,
      The front calipers bolted whit to big bolts part number WHT 004 571 they told me to renew them to , but how tight do a have to fastened these bolts in newton .
      also the rear main caliper bolts needs to be replaced part number N 911 837 01 how tight must these ?
      but i cant find out how to chance those rear pads , the car have also electronic parking brakes
      but someone tels me that the car needs on the diagnose computer to chanche the rear pads (aka VW ) , but i find this strange ,
      i tested wit a piece of paper between pad and disc and activate the parking brake result the paper was not holding tight between pad and disc and feld down.
      because of this i think there are internal brake shoes inside the disc is this correct ?
      any technical help whil be helpful thanks in advance .
      or any exploded view .pdf
      part numbers :
      front pads 958 351 939 , warn contact 958 612 356 00 , caliper clips 970 351 959 00
      Bolt front caliper WHT 004 571 ,
      Rear Pads 958 352 939 00 , bolt N 911 837 01 , caliper clips 7PP 615 269 , warn contact 958 612 365 50
      see pictures
    • By Byron in Atlanta
      Hey guys....I have a clicking coming from the left rear at low speed. I can hear it best when idling to a stop. It does seem speed dependent as it is faster at faster speeds. It seems to go away under acceleration, but I cannot be sure as my exhaust is pretty loud. I jacked the car up and spun the rear wheels, but cannot hear the noise. There is some thumping from the transaxle, but not the same clicking. I checked the heat shield to make sure it was not hitting the rotor. I have taken the wheels off, and spun without the wheels and cannot hear it. I have taken the rear calipers off and removed the rotors to check the emergency brake. There is not a rub or anything obvious that I can see that is hitting or rubbing. I have even removed the center caps and that is not it. I cannot hear it when the weight is off the car. I can hear it when I push the car in neutral. The best way to describe the noise is that is sounds like an old fashioned speedometer cable that is about to break.
      The car drives fine and everything else seems ok. There is no noticeable noise at highway speeds. Any help or advice would be appreciated!
    • By Rosckowff GTR
      When driving i do not hear the sound but when I am slowing down and about to brake I hear a small whine that sounds like a power steering pump in others cars but it is in the front. I have no idea what it is. I has been raining like crazy here but I do not know if that has anything to do with it.
    • By sdharmani
      Loren, All,
      Can you provide any guidance for 2008 Turbo - I have PCCB but want to swap them out with Steel rotors (and matching pads) for front and rears. I am going to be tracking the Turbo, so dont want to damage the rotors.
      Thanks for your help!
