1999 C2 996, (p.s. this was not my car)
Pulled the following codes from a car using Durametric 6.1.x and two different cables. (I can get exact version later).
I think I remember seeing (Porshce) to OBD2 code conversion somewhere, but haven't had time to research that yet. Perhaps these are Porsche codes, not OBD2???
Here's what I pulled from the computer, and I can't make heads or tails of the numbers anywhere (although the text that Durametric provided makes sense, the code numbers do not to me). Maybe this is a bug?
Stored codes:
C0103, Camshaft sensor bank 1 Short to B+
P3015, Camshaft adjustment bank 1
C0013, Camshaft position with respect to crankshaft bank 1 exceeds limit value
C1504, Tank vent system (major leak) below limit value
After clearing the codes, and running the engine at idle and then 3000 rpm, more codes appeared:
P0201 Mass air flow sensor short circuit/open circuit (airbox is out, to be expected)
P1201 Intake air temp. sensor (airbox is out, to be expected)
C0013 Camshaft position with respect to crankshaft bank 1 exceeds limit value
C0103 Camshaft sensor bank 1 Short to B+
(fyi I am pretty sure this is a bad variocam actuator, but it is curious these code numbers above do not make any sense ot me).
25 degrees bank 1
3 degrees bank 2
TIA!!!
Edited by logray
Good, it's not just me then... I didn't have my laptop w v5 on me we were using someone elses. I'll open a ticket with Durametric.
I received the following email from Durametric:
"Thank you for writing. The trouble you are experiencing in version 6.1.1.7 is a known issue. Please upgrade to version 6.2.0.2."
