Durametric is showing the following codes:
Left door module - 8017 and 8018
What are these?
2007 Boxster S, 6 speed.
8017 External BOSE amplifier Malfunction in front subwoofer
Possible cause of fault
- Wiring harness/subwoofer loudspeaker faulty
- External BOSE amplifier output stage faulty
8018 External BOSE amplifier fault in rear subwoofer
If your amp and speakers seem to work fine then I would clear the codes and see if they come back.
