Driving my 2000my 996 c4 the other day. a couple miles after starting when the car was still warming up it just cutout. tried to restart and it just cranked over and would not fire. After a few minutes it started fine and I drove off. A few miles later exactly the same thing happened...
I put my vag obd2 reader on and no codes were displayed. after reading the forums it looked like the crank sensor was the likely culprit so i have just bought a new one and replaced today. Started the car up in the garage and about 3 or 4 minutes of idling during warm up it cutout just the same. after a few minutes it starts fine again.
So what next??
I also read that the cam sensor may be the issue. I have located them and they look very difficult to remove and replace. When investigating more on the left bank one is conected to any wires. the r/h side one is in place but not connected to anything? Firstly is this correct? I guess so as I can not find any loose connectors that may have come off.
If so I was going to see if I can swap the two over rather than buying a new one. Looks like the AOS will need to be removed though for the l/h one.
Any other thoughts on what it could be.
I am trying to source a durametric kit at the moment as maybe my obd2 is not seeing all the codes.
Fuel pressure and delivery is done by connecting a pressure gauge with a side flow port to the test port on the fuel rail (looks a lot like a brass capped tire valve). If the fuel pump is bad, the pressure will not be consistent, or in the correct range. Entire process takes about 15 min. to do.
