Durametrics Log - Misfires/Camshaft Angle
Your data looks confusing; if you let the car idle, does the deviation values remain at a constant number? You should also be able to see a graphic showing both cam's positions at idle, and look something like this...................
camshaft1.jpg?t=1309381620
Hi I only have durametrics software 5 but the first 40 or so rows in the spreadsheet are just sat idling
The Camshaft position 2 deviation is fixed at -2.67 with the actuals (at idle) ranging from 1.55 to -2.63
The actual angles show the amount of variable lift at the moment, which changes depending on rpm and driving conditions. It is normal to fluctuate.
Cam deviation (degrees + or - mechanically ofset from crank TDC) should not deviate.
Read about variable cam timing here:
