Replace the battery without setting off the alarm
Hi there. No you don't need to do that. Just replace the battery like normal.
When you put the new battery in you might need to enter the radio code, reteach the windows, and it will take a few drive cycles before the engine is back to it's normal "peppyness".
UK cars have the tilt sensor and alarm siren. I'm not sure about the 987, but on a 986 you have to switch the ignition on before disconnecting the battery, otherwise the alarm siren will sound.
Yes. Disconnect the negative (black) first, and then the positive. Reconnect positive first, then negative. This prevents shorting out.
The CD24 doesn't have a user-entry security code.
Edited by Richard Hamilton
Agree with Richard, all EU-spec. 986/987/996/997 are equipped with alarm siren, you have to switch the ignition on before disconnecting the battery.
