Tried 2 new batteries an S3 and S5 Bosh and still having the same problems.
2 out of 3 times when I start the car the instrument cluster effectively resets. It goes dark for a split second then flashes back on with the clock reset.
When it doesnt reset (the 1 out of 3 times) when I start the car the cluster dims massively for a split second while the car tries to start
Any ideas what this could be? Starter Motor? Alternator?
You will likely need to have your OPC put a PIWIS tester on the car and also re-program the cluster.
out of interest why would the cluster need re-progamming - the cluster seems fine once the car has started (the problem is just a momentary restart lasting a fraction of a second immediately after the engine has started)
Edited by johnsnow
Because 9x7 series cars are known to have had some software glitches. Re-programming automatically updates the software/firmware to the latest versions.
You can remove them and clean the contact surface but sometimes the fault is within the cable itself. I use a set of jumper/booster cable to provide a substitute ground path from engine to chassis and retest to see what effect it had on the fault.
Great idea I tried this first with the front ground (but had the same result) I then opened the engine bay but I couldnt for the life of me find the engine ground pictured here is there 987 location different?
johnsnow, the engine to chassis ground cable is located underneath the engine.
Thanks, running the battery with a multimeter it records a steady 12.8v even with heaters etc. on seems something is draining it would a faulty chassis ground cause this?
What RPM is that recorded at? Idle? A poor ground will reduce the potential of the charging system so it could be a fault. What is the voltage @1500RPM with no accessories on?
I'm glad you also confirm that the 9x7 clusters had software glitches.
This is still what an expert also confirms to me - while the dealer denies it.
I refused to buy a new cluster yesterday just because the Airbag light does not come on anymore after coding a cruise control.
We'll re-program the cluster with a more recent firmware later this week and will see if that fixes it, in parallel I got another cluster for testing and comparing.
I managed to fix it, there was a blown fuse for the 12v power (the one in the arm rest bit) and I removed the ciggerette fuse also. No idea why but cars works perfectly now
That doesn't make any sense why a blown fuse would impact the cluster in the way you described. I hope somebody can explain it.
What was the fuse number you changed?
It was A8 the thats the 12v one in the rear arm rest isnt it? (the one 2 to the left of the cigarette one on the first main row) Edited by johnsnow
Yes, that's the one. Like wvicary, I was just trying to make sense of it, as there seems no logical reason why that fuse would affect the instrument cluster.
I agree with Richard that circuit does not handle the instrument cluster. The only way I see it could affect the cluster is if something attached to it was pulling the whole electrical system down (which could be a clue to why the fuse blew).
In terms of attached device? If so nothing has been attached since ive owned the car either that or the ciggerette connection. Maybe a faulty connection that shorted? Or a penny thats fallen down the console arm and possibly shorted(ing) it?
