Needle Wobble at Idle
I would start by cleaning the throttle body, a slight wobble every now and than of "maybe" one mm. ( 0.04 in. ? ) seems too little for a ignition related problem. You can always check, with a diagnostic device, for fault codes and actual values to be sure.
