Click here to Donate
Can Airlift be used to purge air from a filled cooling system?
This might be a dumb question, but I'm asking it anyway. I want to replace the heater core/exchanger in my '99 Carrera Cab 6 speed and am thinking about the Uview Airlift system as part of the process. Has anyone used it to purge air from a filled system, or do I need to drain the entire system, replace the core and then refill the whole system using the Airlift? I'd like to avoid draining and refilling the entire system if I can. And while I'm at it, does anyone have the directions for removing the entire wiper linkage with motor? And the torque specs for reinstallation. (Yes, I did a search.)
