Installation of CTEK 56-864 Battery Charger in Cayenne 958
Installing his charger with this connector which has 3 leds on it to indicate battery condition at all times. First picture is what it looks like under the hood. Red cover hides 3 connectors including one big round post. The negative pipe can be seen just forward (to the left) sticking out. It is simply a conductive pipe attached to the frame. I stuck the camera inside to show how the white acorn nut holds the negative conductive pipe it to the frame. This picture shows a closeup of my use o
