Cabriolet Roof Lining Removal Instructions Please
Hi!
Would someone (perhaps Loren) be able to please post the instructions for removing and replacing the roof lining for a MY2004 996 cabriolet (with glass window).
I did search and found people talking about, but no instructions.
DS
hi everyone; i am a first time porsche owner, 01 carrera 4 cabrio. fantastic auto in great condition, 26500 miles on it.my question is about the conv top it is just starting to get a little noisey and operating with a jerky movement instead of smoothly.. any advice would be appreciated.. thanx
I would start with an oil level check of the convertible roof system, if not OK, fill up and check the hydraulic pistons for leaks, if the level is correct, open and close the roof with the engine running and check if everything works as it should now, it would be possible that the problem you mentioned is caused by a too weak battery, with the engine not running.
I sent you a PM.
Hi Loren,
Could you please forward the details to me as well.
Thanks in advance.
If you become a Contributing Member (like the others) - yes.
Done!! Only joined yesterday, so wasn't on top of the whole domate to keep the site going business. Sorry about that.
I sent you a PM.
Hi Loren,
Thanks in advance.
I sent you a PM.
