Click here to Donate
  • ×   Pasted as rich text.   Paste as plain text instead
  • Similar Content
    • By SPIRO
      Hi everyone.  My 2006 Boxster S suddenly started making a squealing noise.  Noise goes away at higher RPM, only to come back at lower RPM and at idle. Not related to gear or clutching at all. Noise seems loudest at the rear of the car; I can hardly hear it inside with the windows closed.  Is this a serpentine belt issue? Or the bearing of some engine accessory? I have 50,000 miles, and have already changed the serpentine belt once, around 4-5 years ago,  just due to age of the car. I have not yet had the time to open up the engine compartment to look further. If it's a belt, then I would expect more noise from inside the cabin, would I not?  I have attached a recording indicating the squeal going away when I rev the engine.
      Recording 26.wav
    • By Garra671
      Tried googeleing it but couldn’t find what I was after.    Was curious if anyone knows what type of flat 6 the 986 boxster has?
      Is it a a true boxer engine? Or a horizontally opposed flat V?     True boxer meaning it has individual crank pins for each piston and is a true 180degree angle.    Thanks in advance
    • By Garra671
      Recently I had been noticing issues with my cooling system the coolant temp guage would go past the 0 on 180 and I wouldn’t hear fans or anything. (Already tested fans and resistors and relays).   The temperature Will continue to creep up if I sit still, with no signs of fans, AC OFF.
      I replaced the coolant temp sensor. Problem fixed!! Then same issue again it seems after a week of driving.
      Now i currently have ordered another temp sensor just Incase I maybe did something to cause the other new one too fail, I’ll be changing it again today.
      However I was doing the climate control hack to check my actual temperatures today while doing a short troubleshooting drive. And I noticed my oil temperature said 0, which is physically impossible 🙄
      Is it possible the oil temp guage is throwing off the coolant sensor?    Is it even possible for the oil temp sensor too go bad but not the oil level sensor? (They are a 2 in 1 sensor)
      THANK YOU IN ADVANCE
    • By Bardia Manafi
      Hi all, just purchased a 1961 notchback 1600s, I have never drove a Porsche until the day I purchased this car, got the bug now and i love Porsches more than ever now, the car is in very good shape, but i want to change all the fluids, grease all the parts, and do all the maintenance there is, the oil was so dark when I checked the level and it was all the way to max line of the stick, i would appreciate if you guys can tell me where to buy all the maintenance parts, and where can I buy the shop manual, and what are the things I should do, there is a small leak on the floor from engine very small, but a palm size of oil from transmission on the ground,  thanks guys cheers😁
    • By salamander
      I have a 2007 C2S manual with about 132K on the odometer.  A low oil pressure light has started to show up at idle after the car is warmed up.  It seems as if the light is gradually coming on more frequently.  The pressure gage on the dash reads around 0.5 bar when the light comes on.  When the car is cold the starting pressure is around five bar and is about 3 bar at 3000rpm.  As it warms up the pressure drops to about 2 bar at 3000rpm.  I always run 0-40W Mobil 1 and change the oil every 5K miles.  With the engine off and turning the key one click the pressure gage rises to about 0.1-0.2 bar.
      Can anyone help me diagnose this issue?  Would be a sensor or something mechanical?
