This is my first post... I hope I am following the proper protocol.... Anyway, I have '01 996 C2. I recently installed a B & M Short Shift kit. I marked my cables as suggested in other posts, but found that the shift way too tight.... I loosened the cables and loosened the screw that is supposed to reduce end-play on the short shifter itself (didn't even feel any end-play after this adjustment). After a couple of days I notice that things have loosened up nicely and have become less notchy... The only potential issue is that there is a little end play now... Is having a little end-play a good/bad thing.... a personal preference.... should I just remove the end-play? Personally, it doesn't bother me that much, but I suppose I'll get used to any tolerable feel as I haven't driven a manual for a long time.... I would like some advice from the more serious drivers out there so I get the most of this mod moving forward.
Edited by On911
The end play (if not excessive) should not hurt anything. Some folks go back in and adjust the end after a couple of years after things are well worn in. If it doesn't bother you then I would leave it as is - but if you start missing shifts you might want to tighten it up a bit. When we install them at our "Work on cars days" we adjust them so that the shifter is just loose enough to return to center on it's when released.
